pharmman »
https://forums.nicoclub.com/pharmman-u28982.html
Sat May 21, 2005 8:21 pm
Hello All,
1993 J30, 130K miles, Florida car, purchased 2 years ago, well maintained. I use synthetic motor oil, changed regularly, Royal Purple transmission fluid. I have flushed the cooling system, fuel system, and had some electrical work (sunroof, windows, door locks). It isn't driven hard, or far.
Apx. every nine months I experience the 'flooded car - won't start" problem described elsewhere in this forum. It has always had a hard shift 1st-2nd, 2nd-3rd, when I give it more than moderate throttle.
Three months ago it began to lose power at 2200-2500 RPM; it sputters like it was running out of gas and refuses to accelerate. If it sits for several hours it runs okay again. It has no noticible problem at idle.
It wants to shift at around 2500 RPM. If I back off the gas for a second as soon as it sputters and then give it pedal again it will shift and I can crawl up to 2200 RPM again.
It was intermittent at first. The mechanic thought it was probably bad gas (charged me to flush my fuel system). Lately, it has become more frequent, and has started to sputter at a lower RPM. It happens after I've applied moderate-full throttle, slow down, and give it gas again.
If I put in neutral it still sputters, and changing gears doesn't matter.
I'm making a date with my local dealer on Monday, but I would love to know what I'm getting into. Any insight would be appreciated.
Thanks.
