I had a thread a while back where I was ranting about my J30 window regulators.
Tonight, I did the window diagnostics from the service manual and it appeared the window motor was dead.
Had a HELL of a time removing the regulator since the window was stuck in the up position and I could not get to the two bolts that attach the regulator to the window glass.
Anyway, took me a while but I was successful in removing the regulator and window motor.
Went to remove the motor from the regulator and it was somehow stuck/bound. Got the motor off the regulator and wondered if that was my problem.
Plugged the motor by itself and voila, it worked. Attached it back on the regulator and it's working fine.
Put everything back. All is well with the window. :ylsuper
BTW - I posted detailed instructions on my webpage with pictures on how to remove the door panel and window regulator.
http://www.fuzzycats.com/j30.htm
Carlos
