j30t wrote:well...the window will roll down fine but it wont go back up unless i push along with pressing the button. Does this mean anything?
That sounds like it's definitely the regulator. When the motor goes bad, the window will be damn near impossible to move with your hand.
The fact that pusshing the window button helps tells me the motor is doing it's thing but the regulator is binding.
Get the regulator and you'll be good to go.
Carlos
