You're in better shape since my starter when good is not cranking. So I am looking for hints on how to test the starter circuit by myself and not blow up a multi-meter in the process. Not easy to turn the key and be in the engine compartment at the same time.Lee Moncks Corner wrote:I have the same type of problem Change Starter, good Bat, and alternator. She will just crank but will not fir up. There is gas I can smellit sounds as if trying to start but but out of order.
Can any one help?
Agree that a bad/possibly shorted alternator will cause all sorts of issues.driverdriver wrote:I'm guessing alternator. It doesn't throw a code when its done. Try replacing it with either an OEM remanned or new unit. Aftermarket alternators create all sorts of electrical and starting issues in this car.
Re: J30 will not start
by swimshark » when you are underneath the car, on the trans there will be the gear selector and off of that there should be a 2 pin connector for the neutral safety switch. if you can get to it try to unplug is and get a short piece of wire and expose the ends of it and place either end to complete the loop on the connector side thats on top. this completes the neutral safety switch and if yours is bad the car will crank and start up.
also on the gear selector, does it feel notchy or does it move freely when you have the key in and depress the brake pedal to put it into gear?
try this and see if this could be the issue.swimshark
