GerryO »
https://forums.nicoclub.com/gerryo-u56567.html
Mon Feb 04, 2013 1:22 pm
Garaged (cold, damp coastal environment) my J30t well over a year ago, and had been starting and running it every couple of weeks for brief periods without any problems, and then the battery went dead. Several months later I replaced the battery and the car starts fine.
It won't idle normally/properly and for long, as eventually the engine dies as it warms up, unless I keep feathering the throttle. It revs pretty good, but it seems better when the engine is colder.
There aren't any codes, though it appeared MAF voltage was low, but cleaning and then replacing the MAF with a $40 ebay special made zero difference. Plugs, EGR, injectors, fuel filter, plenum pull and clean-up, O2 sensors, timing belt and numerous other items have less than 10K miles and 5 years on them. Dielectric grease applied to almost all connectors, and no signs of corrosion or leaks of any type.
Bad gas? Maybe I'll try a fuel additive, a new air filter and adjusting the TPS to up the idle speed, in hopes of making it more driveable.
Other ideas? Thanks!
