IvoryJ30t »
https://forums.nicoclub.com/ivoryj30t-u9485.html
Fri Aug 27, 2004 1:29 pm
the ignition switch is behind the ignition lock.
if your going to fix this your most likely going to need an FSM because the steering wheel will most likely need to be removed, and you need a meter to check the switch for a short and trace it if you have to.
i dont have the premium version of acrobat so i cant post individual pages from the FSM.
BTW, this is an infiniti j30 right? or is it a maxima?
