steelvulture »
https://forums.nicoclub.com/steelvulture-u7079.html
Fri Jun 06, 2003 12:41 pm
Yea, more miles than it would say because more distance per revolution of the wheel. The wheels weren't hard to get on. Just jacked the car up, took the old wheels off, put the new ones on, and bolted everything tight. I was using the original lug nuts so it took a while to put the nuts in and get it started. I just came back from the dealership and got a bag of chromed lug nuts (the caps - the ones you would see on a G35 in the showroom) which are deeper so should be much easier to move wheels in and out (plus they look better). Overall, the wheels weren't hard to get on, just like the original wheels except a bit heavier. And when I first put them on (the front), I had to get down under the car to make sure everything fits just fine and won't rub.
