Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Mon Sep 30, 2002 10:43 am
Be kind of foolish to take old bearings out and then try to take them apart to repack grease, then install old bearing back without cleaning all the grease and examining with a microscope for galling........especially when we give a 12/12k warranty
Time is money.Be very careful as there is a very precise runout spec and if you don't get them perfect, this will result in a wobble in the hub which will cause the rotor to warp.
I know I had to use 3 bearings to get mine right as the first 2 times I ended up with 0.006" not 0.002" as speced.
Some places change them and some places get them back in spec, I usually recommend that the hubs [new lugs] be changed also as they are always bent after 100k of abuse!
