J30 VTC--possible problem
Ken Park
Car: 1991 240SX
I have been trying to figure out what this stumbling problem is with a friend's 95 J30. We have cleaned out the AAC valve, cleaned the MAF, replaced the PCV valves, and it still has a stumble/hesistation after the car is warmed up only. When it is cold it runs great. His cousin told him that the VTC solenoid could be going bad. Anybody ever heard of this?
yodawill2000
Car: 94 Infiniti J30
Knock sensor ??If no check engine light comes on that would be my best guess.
Ken Park
Car: 1991 240SX
When I used my laptop and software on his car once I did see a knock sensor stored code.
yodawill2000
Well there you go !!When they get old and cracked they will do just that.Run great till the engine warms up.Then it retards the snot out of the engine with a false knock code.
misfit6794
Car: 93 J30
I had the same exact problem with mine. I think it had something to do with the egr tubes being completely clogged. Could also be an injector, since when the cars cold its putting a little more fuel into the engine to warm it up, but once warmed the injector isn't pushing aenough gas through. What you can do is to pull the connector for each coil pack to see what cylinder has the misfire. My guess is a fuel injector.
yodawill2000
That would throw a CEL though ,,, Wouldnt it ?
gr8scott72
Car: 1994 Infiniti J30t
yodawill2000 wrote:That would throw a CEL though ,,, Wouldnt it ?
Yes, and yes (EGR and misfire)
Ken Park
Car: 1991 240SX
yodawill2000 wrote:Well there you go !!When they get old and cracked they will do just that.Run great till the engine warms up.Then it retards the snot out of the engine with a false knock code.
I assume this will not throw a code every time then. Where is the knock sensor (s) on this engine?
yodawill2000
Thats the bad news ..Its under the Lower plenum.Some here have relocated it instead of pulling the upper and lower plenums . (Big Job)Do a search and you should find the procedure.
gr8scott72
yodawill2000 wrote:Thats the bad news ..Its under the Lower plenum.Some here have relocated it instead of pulling the upper and lower plenums . (Big Job)Do a search and you should find the procedure.
I'd push my car off a cliff before I replaced the knock sensor. Def look into relocating it instead of replacing it.
yodawill2000
Let me know when your about to push that T off a cliff Scott. I'll come take it of your hands .. hehe
gr8scott72
yodawill2000 wrote:Let me know when your about to push that T off a cliff Scott. I'll come take it of your hands .. hehe
All is good with it right now, but I'll let you know before I do that. Course, I don't know of any good cliffs around here. lol
Q45tech
VVT solenoids and CAS are common old age problems on J30/300zx.
