574-240sx »
https://forums.nicoclub.com/574-240sx-u3281.html
Tue Mar 08, 2005 5:06 pm
Ok first off you need the output flanges and the axels if they are the 5 bolt pattern. If they are the 2x3 bolt pattern you can use your stock axels. Most people say, the drive shaft slops up the extra length of the added ABS sensor. Most of the time the extra length is pushed in to the trans, many times wearing out the rear main seal early. You may want to track down a ABS driveshaft for the future. It should bolt right in but you may have to switch rear covers, I don't have any idea on the S14.
