J30 VLSD Question
Kaioshin1982
Car: Not a 240 =) Thinking of getting one again...
I know this is another topic thats been beaten to death but I just want to get some direct answer.
I'm going to go buy a Vlsd tomorrow off of an Infiniti J30 year is 1995 so I know that it works. What would I need to get excatly? I'm getting it in a junk yard.... Do I tell them that I need the rear differential off of an 1995 J30? and is that all I would need? Or what would be the proper way to tell them so that I dont miss any parts. Thanks in advance
1991S13
Car: '91 240sx Coupe, '00 QX4 4x4, '02 Sentra Spec V
Just tell the guy you want the LSD out of a '95 J30. Everything is the same, except I think the J30 differential has a housing for the ABS sensor on the snout that makes it almost an inch longer, but you should be able to make it fit. The J30's have a 3.916 ratio, a couple percent taller than the open differential you are taking out, but this shouldn't feel any different.
574-240sx
Car: Nissans, Toyotas, Subaru
jusk make sure you get the stub axels(output flanges). Also make sure you get the 2 diff bolts. If you can get the axels at no charge pick them up for the hell of it.
