Well,upon aseembling my subframe, I ran into a small problem..It seems as if the J30 5bolt axles dont work with S13 subframe + 5 Lug hub.
It barely fits, but doesnt..If i can somehow get 1-2mm of clearance, I know I can fit it in, but its not working. If I try to force it in, the back cover pops off because the axle shaft pushes on it and it just turns into a big mess.
Anyone know what the deal may be?or any ideas?
I came up with the idea of taking the links off and angle the rear upright, put the axle splines in and fit the axle to the diff..
But then, I realized if the axles are maxed out, it may pop out the rear cover or even scrape on the rear cover? I'm not too familiar with how the CV axles work..
Help!
