I hate to even mention it but I also had vibration problems before I got the new tires. The vibrations didn't seem related to the wheels. I thought for sure that I was going to need some work on the drive train. I even started collecting estimates etc., for the work and parts. I got the new tires and now all vibrations are gone. An S rated tire should not be on a car that can attain speeds of 130 mph. In fact, the dealer shouldn't have sold them to you in the first place.juiceman wrote:They are michelin Harmony but now that you mention it they have a load rating of 93S (1411@44psi). I did not realize they were s rated.
Man I do not know where to go.
The vibration seems to be from the middle of the car not the outer edges as a tire problem would cause.
Just don't know
The good news is that you have eliminated all the other most likely causes of vibration. If tires solve the problem, then you will likely have one of the smoothest J30's in the world. Everybody always assumes that new tires, especially from a quality brand, are going to be good. The bad news is, well, maybe these ones weren't. Like you say, it's speed related. You changed the drive shaft yet the vibration is the same. The tires seem to be the one constant in this saga if memory serves. Please correct me if I'm wrong about that.
