J30 upgraded ECU coming soon!
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Stay tuned!!!!!!! We're gonna do it!!!!!!
Skapunk4everr
Car: 95' j30
yesss
brandonjustice93J30
Car: 1993 Infiniti J30
any way can ya tie in a new exhaust from the manifold back for the same price with it as well lmao?...j/k
I still really need to get that fixed first when I dont have bills to catch up.
texalmighty
Car: 97 j30
yodawill2000
Car: 94 Infiniti J30
Wes .. Do you know if the J30 Ecu will have the multi program option I read about in the Q forum ?
elwesso
2007 BMW M Coupe
yodawill2000 wrote:Wes .. Do you know if the J30 Ecu will have the multi program option I read about in the Q forum ?
You can have the same options most likely, except the options are just like the 94 ECU. The J30 ECU is basically the same as the 94 Q's, so you can only have 2 programs... Normal/valet or something like that..
The J30 ECU will NOT be as advanced/hi-tech as the Q45 ECU is (since he cant dyno test and theres not as much demand) but it will definitely be as good as JWT for much less money.. Probably better than JWT...
Basically we're going to use the JDM fuel maps (thats calibrated for higher octane gas) and then we're gonna make our own timing maps... Should make for a nice ECU!\
yodawill2000
Sweet , Keep us posted .
DominickJ30
Car: 1993 Infiniti J30t
I dont know if I would trust any untested ECU, is there any way to get a member that lives close by to do some dyno tests?
elwesso
2007 BMW M Coupe
DominickJ30 wrote:I dont know if I would trust any untested ECU, is there any way to get a member that lives close by to do some dyno tests?
There may be, but like I said, his program will be completely safe, i would personally trust his tuning abilities... Lets say that the factory leaves 20% safety in, his normal program cuts it down to about 7-10% maybe..... If I recall correctly, the first program he made me was not dyno tested at first..... he made the more advanced program that I am currently running on the dyno...
DominickJ30
elwesso wrote:There may be, but like I said, his program will be completely safe, i would personally trust his tuning abilities... Lets say that the factory leaves 20% safety in, his normal program cuts it down to about 7-10% maybe..... If I recall correctly, the first program he made me was not dyno tested at first..... he made the more advanced program that I am currently running on the dyno...
So you obviously agree that a dyno tested program is much better.
Where is this guy located?
elwesso
2007 BMW M Coupe
He's in LA... Im not 100% sure how my program worked out or not, he may have dyno'd to begin with but the Q45 base is a LOT bigger... We've sold i think about 35 NICO ECU for the Q, i doubt we'll do 1/2 that...
bottom line we simply arent going to make the J30 program as advanced as the Q45 program is.....
Skapunk4everr
Car: 95' j30
And, I am the guinea pig. The first one is being tested on one of my ecu's. Lik ei said to Wes, ill report any problems that arise.
Big Tone
Can someone educate a noob like me? What options are present in the custom ECU that aren't in the factory one?
93j30t
how much?
elwesso
2007 BMW M Coupe
Big Tone wrote:Can someone educate a noob like me? What options are present in the custom ECU that aren't in the factory one?
More HP...
93j30t wrote:how much?
Looking like it will be less than 150.
Big Tone
elwesso wrote:
More HP...
Nice!
93j30t
what kinda hp gains would we expect?
elwesso
2007 BMW M Coupe
93j30t wrote:what kinda hp gains would we expect?
Maybe 20HP? Similar to JWT.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Wes, any chance for an SOHC variant?I want one for the Maxima.
elwesso
2007 BMW M Coupe
Depends on how the ECU works... it just so happens the J30 ECU is identical to the 9495 Q45 ECU.
NY94J30
Car: 2000 Q45 AE
Hey Wes, I assume that the ECU upgrade will be limited to OBD I models?
elwesso
2007 BMW M Coupe
NY94J30 wrote:Hey Wes, I assume that the ECU upgrade will be limited to OBD I models?
93j30t
niiice... 20 hp for 150? shoot yea
marosari00
Car: 2012 M56S (Stormie), 2010 Mercedes C300 Sport (Capri)
Hi!
Any status on this endeavor?
V/R,Manuel
elwesso
2007 BMW M Coupe
skapunk got his ECU, just has to install it...
