J30 Turn Signal Flasher
J30-Max
Car: 93 InfinitiJ30- 99 Maxima se
I have a 93 J30 and ran into a problem I can't figure out. Recently my turn signals were intermittent now they do not work. Also my hazard lights do not work. I have tried squeezing myself under the dash/ steering column area but nothing under there looks like the typical turn signal flasher unit. Does the J30 have a turn signal flasher unit? If so where is it located? Or a relay and its location? I have checked the fuses they are good. And just for the heck of it I changed the hazard switch. Any help would be greatly appreciated. Thanks
DominickJ30
Car: 1993 Infiniti J30t
You checked the bulbs right?
1993TanJ30
Car: 1993 J30
Like Dominick said - first thing to check is the bulbs. Sounds like you've probably already replaced them if you've tried all those other options. Let us know.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Theres a relay in the underhood compartment.....
J30-Max
Yeah just checked the bulbs again. they are all good.
DominickJ30
J30-Max wrote:Yeah just checked the bulbs again. they are all good.
Get Wes to email you the J30 FSM and look for that relay like he suggested.
yodawill2000
Car: 94 Infiniti J30
I got that from Wes and wouldnt ya know it doesnt have the fuse box diagram !!! OOiy !!!But it does have about everything else I need ..
Thanx again Wes'ter !!
elwesso
2007 BMW M Coupe
Theres only 3 thigns it can be... The bulbs/sockets, the relay or the switch, assuming the wiring is not severed somewhere.....
J30-Max
I just gota fax back from the local Infinity dealership. Its the wiring diagram for the turn signal system unfortunatley, the quality of the fax isn't too clear. It doesn't have a very detailed location of the underhood relay. Can you tell me exactly where it is....Thanks for the info.
DominickJ30
Post your email addy so Wes can send you the whole Factory Service Manual through email.
elwesso
2007 BMW M Coupe
Heres what I found after digging through the FSM...
Theres a combination flasher control unit apparently (my guess its just a big relay)... it controls the timing for the keyless entry, hazards, and things like that... basically it controls the high voltage part of the bulb in the corner lights and the rear lights.....
This is really the only thing in the wiring diagram that I found of use... I scoured it as well...
elwesso
2007 BMW M Coupe
LIke thepicture says, we're looking at harness number M46
Hers an expanded view so you can tell where to look..... The bottom line, its a PITA to get at!
elwesso
2007 BMW M Coupe
Aww hell while we're at it might as well post the wiring diagram as well..... hopefulyl someone else can use this..
FYI i will probably upload all these onto my website, as i have a TON of q45 and J30 snippits from the FSM, but I always post them in threads. Attaching them assures that they wont be lost, because we lost some pictures in photopost and also i dont trust outside hosting services..
J30-Max
Sweet.....Your the best!!!!!!!.....I will dig into the car in th A. M. ...Thanks
yodawill2000
Mine has the layout of the fuses/relays on the inside of the cover ..(Under the Hood)Sure wish the one on the inside fuse box was labled !!!
