Fix for 2 problems in MK1 Automatic Transmission
I am the original owner of a 1987 MR2 Auto with 136,000 miles. Over the years I have had 2 problem with the transmission and both times when I talked to transmission shops there only solution was rebuild it. Had I listened to them the first time the rebuild would have not corrected the problem. The transmission would not shift into overdrive until I had driven at least 5 to 10 miles. This problem was solved by changing a stuck thermostat. Seems as though the computer will not let the transmission shift into overdrive untill it is fully warmed up.
The second problem was a little more scary. The transmission would not shift into low gear when I came to a stop. But I could manually shift it in to low and it would work fine. Then it started sporaticlly shifting from low gear to 4th gear skipping 2nd and 3rd., the rest of the time it shifted fine. Seemed to act up more when it sat for a week or 2. Ordered a set of 3 Solenoids, #1, #2 and overdrive around 150.00 and had them installed. Just a matter of dropping the pan like you were doing and oil and filter change, removing the old and bolting in the new.Transmission is now shifting like a new one. Problem solved.
It just amazes how nobody has the ability to diagnose and repair things, there only solution is just rebuild it. Hope this post saves somebody a buck and takes a rebuild away from one of those shops that cant fix anything without rebuilding it.
Copied from here:
http://www.mr2oc.com/showthread.php?t=433164
You may need to join in order to read the actual thread and it sounds like the temp signal/sensor might be flakey, as OD lock isn't supposed to happen until things are warm, or maybe a solenoid is very slow to open or close, or maybe a lighter foot on the gas pedal will help, which makes me think of replacing the TPS or a kick-down switch adjustment?
