ROT8TOR »
https://forums.nicoclub.com/rot8tor-u141031.html
Fri Oct 16, 2009 6:40 pm
I'm not absolutely sure, only because you say when it warms up, it'll shift.
First...Can you do a self diagnostic test on a 240??
Secondly, I would see if the linkage, itself, is properly aligned and tight.
Then, if that doesn't fix it, find an inhibitor switch.
Incuding mine, this will be the 4th one I've fixed with the same problem.
