I have a 94 J30 with 230k+ miles and just recently the transmission stopped engaging reverse. All forward gears work fine, no slipping, hunting etc. Checked the transmission fluid (engine running, transmission in neutral) and it was slightly low, added about a quart and reverse began to engage again then after some toggling between reverse and drive it stopped engaging.
Did some searching and saw some people with similar problems but no definitive fixes, just wondering if anyone has encountered this and solved the issue. Thanks.
