The J30 does indeed have a replacement filter that has an improved design. Getting the pan off and having a knowledgable tech show you whats in the pan and collected around the magnet can give you the inside story on your transmission. It's a messy job and because there is some skill in reinstalling the pan to get it right the first time so that it doesn't leak you might want to take it to an experienced guy. The VG30DE in the J is a standard Nissan engine. Any Nissan dealerships close by? A good independent shop can also do this service.carlos_knology wrote:Hey everyone, I just called Troncalli Infiniti in Atlanta to inquire about a transmission flush for my 95 J30.
I'd take it to T3 except that they're not open on saturdays and I live about 140 miles from atlanta. No local dealer where I live.
Anyway, when I asked about the filter replacement, the service writer tells me that the J30 has no serviceable transmission filter. Is this correct?!
It sounds like they just basically run new fluid through the system. Does that sound right to you J30 owners?!
They said they don't even drop the pan.
Carlos
carlos_knology wrote:Did you do it yourself? If so, should I change it before the flush or after?
carlos_knology wrote:When I asked him about switching the fluid to synthetic, he said it was safest to stick to whatever the manufacturer states. He said my car doesn't come with synthetic.
Should I insist (i know it costs more) on the synthetic atf fluid?
Carlos
carlos_knology wrote:The service writer at Troncalli said if I really wanted the filter replaced, they'd do that for an additional $150.
