J30 transmission cooler recommendations
juiceman
I cannot see spending 150 to 175 fromlocal shop for cooler
What cooler has anyone used for this car and how have our routed the hoses? Bypass existing radiator (just changed TC, sludge inpan etc) or with existing?
The lower cover does not allow for the hoses to go under the cross member and I am afraid to cut and route that way as they will be exposed to parking stop damage etc. Too exposed.
Thanks for anysuggestions.
B&M... I think model # is 70268. $50 at local autoparts stores, or order from Summit Racing (free shipping).
You can bypass the radiator but it's not necessary. Mount in front of the condenser in the path of good airflow for best results.
juiceman
I did a search and that is recommended for the Q45 but will it fit the J30?
Also what to do to route the hoses. No real room and going under the cross member exposes the hoses to possible road damage
Shouldn't be much difference. They're both big cars.
No need to go UNDER the radiator. Look for a route alongside it. Mine run right past the headlight mounting brackets.
Thre's no RIGHT way to do it as it's really a part for a tow vehicle or a motor home anyway... You have to get creative.
