J30 Tire Thread
NY94J30
Car: 2000 Q45 AE
We don't have one of these in the J forum. It seems it would be a good sticky.
Brands, sizes, load index, general comments on wet/dry traction, handling, sidewall flex (a problem I've found b/c of the Js weight), road noise, price, etc.
Modified by NY94J30 at 1:56 AM 12/19/2006
xxcrashxx
Car: 95 Infiniti J30
this thread might be of some use.
zerothread?id=108009
NY94J30
Car: 2000 Q45 AE
I have run the following:
Dunlop SP Sport A2, 215/60/15, load index - ? probably not high enough - relatively loud, tons of sidewall flex, tread wear was abysmal considering a 450+ treadwear rating, I got 8,000 miles before reaching the tread bars on a 20,000 mile tire.
Falken Ziex 512, 235/45/17, load index 97, a great tire, I'm sure the extra 20mm helped alot, but the handling was night and day, far more sticky and planted. Keeping the Js tail in line became a far easier task - in the wet as well. Little flex, but obviously a lower profile. Relatively quiet as well. And a good price at around $90/ea.
Falken Ziex 215/60/15, 94, a far different tire than the 17 inch Ziex, different construction, far less aggressive tread compound, slightly louder, not nearly as sticky, still not too much flex. Wet traction still leaves something to be desired. I'd give it a recommendation for a cheap tire - I thought I was getting the same tire I had in the 17 inch.
NY94J30
Car: 2000 Q45 AE
xxcrashxx wrote:this thread might be of some use.
Yeah, I remembered it, however, I thought it'd be better to get some information catered to the J in here since the traffic here has picked up lately, and Infiniti General used to cater mostly to the Q crowd before the split.
NY94J30
Car: 2000 Q45 AE
Bump.
Anybody else have tires on their J30, like me?
DominickJ30
Car: 1993 Infiniti J30t
If you want to sell the operas or whatever they are I could probably take em off your hands if the price is right.
NY94J30
Car: 2000 Q45 AE
They are 17x8 OZ Opera Is. I may part with them, I have some details to work out first. They look amazing on the J in my opinion, by the way. I will keep you in mind when and if the time comes.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I left the tire review thread in Infiniti general so that everyone could join in!!
However if you guys keep this thread alive with good info I'll sticky it!
driverdriver
Car: NICO's longtime resident Canuck!!!
Like Wes, a lot of good info on this thread, including J30 tire info.
zerothread/108009
Nissansbitch
Car: 1994 Infiniti J30
http://www.bridgestonetire.com...=1112
I use the Potenza RE960AS Pole Position on my 1994 Infiniti J30.
Sizes and Specifications Print Product Sheet Innovative Tire Design - A Comprehensive Tire Design MethodThis method improves handling in wet or dry conditions and reduces irregular treadwear by combining an ideal tread design, casing, shape, materials and construcion.Innovative Roundness - Rounder is BetterRounder overall tire shape provides better balance for wet or dry handling. Super L.L. CarbonThrough microtexture technology, the wear-resistant properties of this special carbon black have been combined with higher rubber flexibility, a key factor in longer wear.Super EPOSuper EPO goes beyond EPO in providing wet handling as the tire wears. The interactive elements are Super EPC and an enhanced version of Dual Layer Tread.Super EPCSuper EPC consists of advanced technologies, an Anti-Hardening Resin and Link Stabilizing Agent, to help counteract the effects of heat so tires have the flexibility needed for wet performance as they wear.Dual Layer TreadAs the tire wears, more of the inner tread is exposed so the tire continues to have excellent grip in wet conditions.SilicaSpecially formulated and processed compound to improve traction, especially in wet conditions.Hydro Evacuation Surface (H.E.S.)H.E.S. more efficiently channels water away from the tread to reduce the risk of hydroplaning.Consistent Surface Contact (C.S.C.)C.S.C, a pattern of tread blocks designed for uniform contact pressure, improves dry and wet handling, reduces irregular wear, and results in better ride comfort.
Warranty Summary:Platinum Pact Limited WarrantyBuy & Try 30 Day GuaranteeStandard Limited Warranty
The BEST tire I have ever used. Handles the ice better than studded tires. Did not use studs this year in Oregon because of this tire. And I only have two on the rear. Have put 10k on them, and they look great. Cannot break them loose in dry weather. Have to really, really try in wet weather.
I must add, it doesn't matter if your car is front or rear-wheel drive--THE TIRES WITH THE MOST TREAD SHOULD ALWAYS BE ON THE REAR WHEELS.
