J30 timing belt tensioner
redboeing
Car: Infinity J30
My Infinity dealer told me that when I bring my J30 in for timing belt replacement, they might replace the tensioner at the same time, an extra $450 job. I just wonder if any J30 owner found it necessary to replace the timing belt tensioner? My J30 is of the 1993 model and had about 115 K miles. This would be the 2nd timing belt.Any feedback would be greatly appreciated.
yodawill2000
Car: 94 Infiniti J30
They suggest the tensioner and water pump with a TBelt exchange.450 is mighty steep since they are already in there !
I'll be doing my own when the time comes.If I recall the whole TBelt kit from Joe is less than that.
NismoChi
Car: 94 J30
WTF, $450 extra for replacing the tensioner, are you kidding me, the tensioner only cost ~$130, so they charge you $320 for a 3 minutes jobs. WOW!!After the timing belt is off, and 4 bolts the tensioner is out. If there is no leak, yo don't have to replace it. That is what the part manager told me.
infinitidreams20
Car: 1994 infiniti J30T
NismoChi wrote: If there is no leak, yo don't have to replace it. That is what the part manager told me.
what do you mean by this? leak? i am about to do the hole timeing belt job myself and was wondering about the tensioner i have a 145,000 miles
NismoChi
Car: 94 J30
We have a hydraulic belt tensioner to keep thetension on the timing belt, if there is no leaking of fuild on the tensioner, you can reuse it.
infinitidreams20
hmmm sounds like that would make sence thanks
still worries me 130 bucks is so much cheaper then a new motor ha that smiley looks so spazed out
Defiant
Car: 1997 J30
redboeing wrote:My Infinity dealer told me that when I bring my J30 in for timing belt replacement, they might replace the tensioner at the same time, an extra $450 job. I just wonder if any J30 owner found it necessary to replace the timing belt tensioner? My J30 is of the 1993 model and had about 115 K miles. This would be the 2nd timing belt.
Loud dinging, accompanied by a bright flashing yellow light. If you meant 115K on the motor, you should not be due for a belt. If your '93 got a new belt in the vicinity of 60K, the replacement by then was kevlar, with a service life of its own of 105K miles (if it's 115K on the belt, then you're pushing your luck). And extra $450 for a tensioner is absurd. That must be for a $375 part, which is criminally inflated. "Might" replace it during a timing job is also suspect- the water pump and tensioner are routinely replaced along with the belt.
I would seek out another shop.
redboeing
Car: Infinity J30
My local Infinity service department guy told me that the tensioner costs $350 (Cdn), plus 1/2 hour of labor, $50. Plus GST and PST, the total for this alone is more like $500, which converts to $450 US roughly.
