J30 Timing Belt Replacement Procedure
95J30tBGGUY
Car: 1995 Infiniti J30t
Wow Thanks a lot :bowrofl: . I'm gonna do that if not today, tomorrow. I just wish the pictures were still available. My water pump is licking so I got a new one from a dealer and I went with all the belts as well. I have just one concern of tightening the timing belt to much :ohno: . And exactly how do you set the autotensioner at 4 mm. And do you turn the crank shaft clockwise 10 degree then back (counterclockwise) 120 degree and again 120 degree clockwise if I recollect it right to tension the timing belt ?
skirod
Car: 1993 j30t
any way to get a set of the pictures i am about to replace my timing belt pulleys and water pump.
swimshark
Car: Bamboo Mist 1994 Infiniti J30 Soon to RIPs
Pearl White 1993 Infiniti J30 Project Ghost
this is the furthest i have had my motor torn down while doing timing belt and a few other things.
EriCCirE
Car: 1993 Infiniti J30
Found these back from when I did mine in 2010
