trissdv »
https://forums.nicoclub.com/trissdv-u205751.html
Mon Sep 24, 2012 3:41 pm
I have a couple of questions. Myself and my roommate who has mechanic experience have been trying to change the timing belt on my '94 J30. I got it used, and don't have much in the way of it's service history, but at 113k miles (got it at 103k) I'm going to assume it was time for the timing belt to be changed, possibly way passed due. And in fact there was a hole eaten in the middle of it so good thing too! My questions will follow in the later portion of this post.
Anyways the roommate is the one doing most of this, my knowledge is limited, and he didn't take a lot of precautions when tearing everything apart since he's familiar with the procedure (I'm sure just with domestic brands mostly though). We've tried several times to get this to work but the timing hasn't been right. Someone did paint some marks on it, and has been in the engine before he is certain. We finally got the belt on at what we thought may be right, and the car starts but idles high now with occasional dip and surge and when accelerating it sputters and acts like it wants to stall after letting up on the gas. I haven't put it on the road, it's still jacked up, so this was just testing. Now come to find out someone thinks it may have a '93 engine in it for whatever reason and says the belt is entirely different and longer. Things no matter what, if lined up with the marks ON the belt is a tooth off. He claims he let it be off one tooth but kept the mark on the sprockets and back cover lined up for that almost successful attempt.
We got the belt for a '93 and are trying that but ran in to the same problem. It isn't any longer it seems and still wants to be a tooth off. This time he's putting it together with the marks on the belt matching the sprocket, but one sprocket being a tooth off from the back cover to see if that's any better. This way the tooth count as laid out in the procedure found here and what is in the instructions is correct.
First, is there any way to tell what year the engine is? Second, does anyone have any insight about the timing? The marks don't line up, so what can be recommended? Thanks!
