I completed the task of changing out the timing belt, timing tensioner, and water pump according to this:
zerothread?id=198122
However, as I go to start the engine I fill up the radiator which I know will not fill the engine(if you have a tip on how to do this i would appreciate it). Now, the engine will crank, it runs for a little bit and I get a really high pitched belt squeal, could that be because of an accessory belt I tightened too much? Also, I go to start the engine a third time and it makes a noise like the starter is grinding against the fly wheel. Could I have misaligned the starter?
Any thoughts would be greatly appreciated.
Sean
