edgartheace wrote:For me at least it was avoiding the hassle of hoses under the plenum tearing, or rupturing, which was a pain in the @$$ on my 240sx, I can only imagine what it is like on the Z. Then there is also the argument that why would you put a CAI only to reheat the air at the throttle bodies and the plenum from the coolant hoses that pass through there. I wouldn't recommend it if you live in an area with -0 temps, since the coolant was circulated through the throttle bodies to avoid icing.
I can see doing it for the sake of not having to worry with the hoses but the argument of doing it to gain power, well, that's just silly. A VERY small portion of the TB is heated and it is only heated to keep it from freezing. You will in no way be able to tell the difference by seat of your pants dyno or even a real dyno by bypassing them.
