j30
lunaivan
Car: making money
does anyone know where i can get parts for my infiniti j30 suspension. at a reasonable price. i live next to the infiniti dealer but i just want to know if i can get some cheaper prices. also if my car vibrates when im at a complete stop, does that mean that i should clean or replace my fuel injectors. one more thing does anyone know someone in the southern california area that does good work on infiniti.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
A lot of questions, but for parts call the guys at http://www.everythinginfiniti.com and get your car to http://www.jerrytucker.net for a diagnosis and start a maintenance program.
VimyJ
What's you idle RPM? Have you cleaned the throttle bodies?
Welcome to the club.
lunaivan
Car: making money
i havent cleaned the throttle bodies,what does idle mean. not familiar with that word.
VimyJ
lunaivan wrote:i havent cleaned the throttle bodies,what does idle mean. not familiar with that word.
I'll not poke fun at you personally, but we have a little running gag with "Newbie" questions. Your "what does idle mean" is going into the hall of fame.
Don't worry, we were all newbies at one time.
Idle could be described as your car's resting RPM. When you have the car in park and engine on at normal operating temperature, what is the indicated RPM?
lunaivan
Car: making money
i idle about 700, then my car vibrates and the rpm goes up to 1200. i was moving my tps around so i believe thats why its doing that. i might just have to go to the dealer and have them check my car on the computer.
Q451990
lunaivan wrote:i was moving my tps around so i believe thats why its doing that. i might just have to go to the dealer and have them check my car on the computer.
No doubt... the TPS adjustment is critical!!
VimyJ
Never mess with the TPS.
mateo
With newbie terms in mind... where would one find a dictionary of car terms and part names (ie TPS, Plenum).
Q451990
Good question! I'd say start at http://www.howstuffworks.com - but the terms vary a good bit with models and even who's talking about them. For instance, the Plenum could also be called the "intake collector" or "intake manifold."
Heath
Eswift
Car: should be obvious enough
sounds like your AC compressor is kicking on and off, and your engine is not in quite in tip-top tune.
Eswift
cweberj30t
Car: 1993 J30t
2003 G35
2007 G35X
2011 G37X
lunaivan wrote:i idle about 700, then my car vibrates and the rpm goes up to 1200. i was moving my tps around so i believe thats why its doing that. i might just have to go to the dealer and have them check my car on the computer.
You aren't sure what Idle means and you were moving your TPS?????????????????????????????????????????????
