GerryO »
https://forums.nicoclub.com/gerryo-u56567.html
Wed Oct 07, 2009 5:38 pm
Regarding the fan, you might try searching this forum for the Darlington Resistor.
Trunk-wise, mine wouldn't stay closed after it was opened using either the driver's door mounted switch or the key fob button. A gear inside the opener would over-rotate, leaving things stuck in the OPEN position where things wouldn't latch. Pulling the small motor assembly out, opening it up and removing a few teeth from one of the gears fixed that.
