alexhho wrote:Hi VimgJ. I just read your recommendation on fixing the "binding" window. My 97 J30 is experiencing the problem with its driver-side door. Can you tell me what tools do I need to replace the window regulator? Will I need to solder anything? Thanks for your help.
I've replaced both passenger-side window regulators and one window motor. If you don't replace the regulator when the window starts to bind, the teeth on the motor gears (made of plastic) will strip and you HAVE to replace the motor.
The window regulator runs about $75-80 and it's a DIY job. No soldering of any kind. Just remove the door panel. Roll or push the window about halfway down and remove the two bolts holding the glass to the window regulator. Since you're working on one of the front doors, you'll have to also remove the plastic speaker housing since I think one or two of the bolts holding the power window motor are behind that speaker housing.
In any case, the window regulator is a metal piece (a track that guides a piece attached to the bottom of the glass window). On top and bottom of that metal piece there are pulleys with a cable that runs over to the power window motor. The cable looks like the brake cable on a 10-speed bike. You cannot replace just the cable. The whole thing is one unit.
Since the regulator is attached to the power window motor, remove the four bolts holding the regulator to the door (two bolts on top, two on bottom), and I think there are two or three more bolts holding the power window motor in place. The regulator and power window motor will come out of the door as one unit. You just squeeze both of them out of that small hole in the door. Once you take a look in there, it will all make sense.
Once you have the window regulator and motor out of the door, remove the power window motor and attach it to the new regulator. From that point on, just install it the new unit.
Should you discover that the window motor has some stripped teeth. I found that my local Discount Auto Parts sells remanufactured Infiniti power window motors for $50 (as long as you give them your old one as core) with a lifetime guarantee. I've had one of those rebuilt motors for over a year and a half and it's worked fine. I think the factory motor is around $200 but don't quote me on that.
I think I covered everything...... let me know if you have any other questions. Email
[email protected] if you have questions.
Carlos
