J30 Suspension
marosari00
Car: 2012 M56S (Stormie), 2010 Mercedes C300 Sport (Capri)
Hello!
My 1994 J30 has 122K on it and after replacing water pump, front seal, all belts and hoses, the next step is suspension.
Is it enough to replace strut inserts in the front and shocks in the rear, while keeping the original springs?
Thanks!
Q45tech
Enough for what? Examine all the rubber bushings for wear and deformation.......how are the tension rods and sway bar bushings and rear end links?
VimyJ
Your springs should be fine unless there is heavy corrosion. All the rubber bits are probably done for after 10 years of exposure to the elements.
LuvMyJ
Car: My J30, Flying
I'm getting ready to replace my right rear strut. Can anyone outline the basic procedure for me (in a little more detail than "Take off old strut, put on new strut"!). Are there any special tools required or recommended?
Thanks,Bob
marosari00
Hello!
Thank you all for the comments. I will definitely have the springs, bushings and links inspected and replaced accordingly.
V/R,Manuel
