J30 sunroof/ cd player
reptile28
Car: 1992 300zx 2+2
The sunroof on my 1993 j30 is stuck openWhen the up button is pressed , you can hear the motor working but nothing moves. None of the other buttons even make noise when pressed.
Modified by reptile28 at 4:56 PM 5/12/2007
gr8scott72
Car: 1994 Infiniti J30t
If you can't find the fuse how do you know it's out?
And you will need to be more specific on your radio problem. (picture woudl help greatly)
reptile28
Car: 1992 300zx 2+2
cd player is fixed but i still don't know about the sunroof
gr8scott72
Could be the switch gone bad. You might still have the original sunroof tool in your jack tool bag. You can manually close the sunroof with it.
reptile28
Car: 1992 300zx 2+2
thanks, the tool was in the bag and i closed it, and iv discovered that the open button also works, the only thing the car won't do is close it.
littlewillie
Modified by littlewillie at 11:47 PM 12/23/2007
gr8scott72
Sounds like that might fix it but it's SOLDER, not solider.
reptile28
Car: 1992 300zx 2+2
where and what is the solder joint?
