why not try S14 rears on the j30? they are longer than s13 and should pick up most of the 3" slackk4rr wrote:I put s13 struts on the rear of my buddies J30
I had to cut one coil off the top of the stock s13 springs for the j30 tophat to fit.
It is a larger diameter than the s13 and the mounting points of the j30 top hat are wider. So the J30 tophats had to be used.
S13 stock struts and springs lowered the car in the rear 3 inches.
The car bulldogs now! Be are gonna install s14 front spindles and struts on the front next.
Yes it would beelwesso wrote:Very nice!!
If you could put S14 coils onto a J30 that would be simply fabulous!!!
i hear you on that!!!!!!yodawill2000 wrote:Wish somebody would figure out a cheap bolt on replacement for the front struts !!!
Not the suspension. The J30 suspension is actually much closer to the 240 with the mcphearson struts and the multlink in the rear..krin2000 wrote:i hear you on that!!!!!!
how does the 300z fairlady differ from the j30t? i hear they are a lot alike
