I recall reading about the fuel rich/cold start issue on J30's (I own a 93 J30t ) but I cannot place it..
First off, don't pump and dump the gas pedal with starting issues. Lot of folks tend to think this is a studebaker to pump and prime..this only makes it worse.. This is a computer controlled, fuel injected vehicle.. All Nissan products have an flood protection circuit tied into the ECCS (main computer) The rule is to floor the gas pedal while cranking so the car actually gets starved of fuel to clear the flood(ing) When you floor the gas pedal, the ECCS knows it is in open loop (car not running, sensors not active) courtesy of the TPS (throttle position) sensor(s) telling it to cut fuel to clear a flood condition. This is how you clear a possible flood condition on every nissan fuel injected product anywhere you go in the world.
Start with the basics.. a tune up...plugs..filters..fluids etc. With this out of the way, these cars are the most notorious electrical gremlins known to man. A quarter of their issues occur from bad soldering on circuit boards which result in cold spots over time..bad for things computer controlled. On my 93 J30T I had to resolder to fix a bose headunit issue, dimmer switch issue, and door lock timer to fix the door locks from locking randomly.. Check all the grounding points on the car.. Check the Mass Air Flow sensor and it's contacts. Check the Throttle position sensors and it's contacts. Check the coolant temp sensor. This sensor is the most basic thing that can fail. It reports temperature to the ECCS before you even start the car.. Failure or laziness in this sensor can cause the issue you stated.. I have seen it on maxima's many a time. The sensor is reasonable..under $50 and looks like this:
http://img.thepartsbin.com/live/C6020113284FOR.JPG Check the fuel pressure circuitry..fuel pump, sender, fuel pressure regulator.. Clean the throttle body thoroughly. After cleaning, your idle will shoot up for a bit.. If you can live with it...the ECCS will automatically calibrate in a couple of days, otherwise, reset the base idle. Do a check into the fuel injectors.. there is a cold start injector/circuitry in these cars.. look into that..
I looked up some postings outside of here..
http://www.automotiveforums.co...32887
http://www.nissan-infiniti-for...00021
Abdul
