diamondj30 »
https://forums.nicoclub.com/diamondj30-u656.html
Sat May 31, 2003 3:16 pm
coilspringspecialties.com .they can make you some.other members have done this.dont know if its a com or not.try a search on nico you should find we have covered virtaully every aspect of this mod..you dont hear me saying this but,(if only 1 or 1.5 drop i would have cut mine.but i had a master plan.and means to do things.if you want to go into why i run 1250.00 rear struts,well this is what i mean.personally,the bounce can be handled by koni yellow but on the back,your on your own.intrax were just real weak spring thats how they had to do it.because a strong spring,would fall to short and could not gaurantee it would jump the lower colar.mine are accually tied in so when the car is servised they would stay. put.im 40% over stock.on flat ground mine sits right at the top of the fender lip.on the tires.4 inches of clearance underneith the front.clears almost all speed bumps.think how high a 4" speed bump would look.with 4 inches under you you cant afford to bounce.what ever you decide,remember this(new or cut you will bounce alot.)without quality struts.that is.)hope this helps.
