kaizady »
https://forums.nicoclub.com/kaizady-u6982.html
Tue Jun 10, 2003 12:05 pm
Hi:I have a 94 J30, with 59k miles on it. When the car is on park, the cars tremors a bit when I press on the gas at approximately 1600 to 1800 rpm and then at 2200 to 2400 rpm. I put my hand on the steering wheel and I can feel a slight tremoring at these rpms.
It does the same when I drive it. I jsut had new rotors and pads put in the front, because the car used to vibrate when i braked, thats fixed. I have also done the wheel balancing. The mounts look o.k. Do you thing there is a problem with the brake work, or there may be a problem with the fuel injectors.
The transmission shifts just fine. a year ago I changed the spark plugs, used oem ones, transmission pan drop, filter change and fluid change (Mobil 1 ATF). Is there a problem or am I just being paranoid. I donot have the repair manual that comes with the car. Any help or suggestions would be appreciated.Thanks!
