J30 shakes when driving it
psychx
Car: Infiniti J30 (VG30DE)
It feels like it is coming from the front.. When I hit a certain speed it will shake pretty hard, and overall driving it around it shakes a little bit and is very annoying. Now there are 2 things that I am going to be fixing: 1) I just bought a new power steering pump, and will be putting that in sometime today. As of right now I do not have power steering. and 2) I think my front suspension, or part of it, is blown. Too many miles I guess.
Could it be just the suspension doing this? Or is it my rotors? Or what?
J30inthe sun
Car: 1997 J30
I just rebuilt my entire front suspension (struts, upper strut mounts, springs, tension rod bushings, rack, outer tie rods, stabilizer bar links & lower control arms) & I had a vibration problem starting at @65 mph. The culprit was the lower ball joints (totally shot) which you have to buy the entire lower control arm @ $190 each. I am at 113,000 miles, 97 J30.
I have experience wheel vibration with old worn rotors before.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
What about motor and transmission mounts when were those last changed?
J30inthe sun
Car: 1997 J30
My mechanic check them over & they were rock solid, I had questioned them as well. My car rides like brand new now, no vibrations & rock solid at 90+ mph now.
farari69
Car: 1994 Infinity J30t
i was wondering what you replaced or fixed to stop the vibration at 65. mine does it at around 55. thanks
J30inthe sun
Car: 1997 J30
farari69
Where did you find the lower control arms for 190.00? the cheapest I have found was 250.00.
J30inthe sun
Car: 1997 J30
http://www.infinitipartsusa.co...gid=0
Lower control arm, j30, right - $182.70Lower control arm, j30, left - $178.93
Plus shipping.
My local mechanic charged me $190.00 a piece, it was a no brainer.
Look at the rubber boots around the ball joint, mine were totally deteriorated.
infinj30t05
Car: Infiniti J30t
Mine used to do that it was my tires...once I changed all of them it stopped...I didn't realize bad tires could make your car shake but it did!
