try recharging the AC system...also check between the condenser and the radiator and see if there are leaves or something clogged in between...lastly but highly unlikely it could be the ac compressor...
driverdriver wrote:Welcome to NICO!!!
All J's came with factory air, run the temperature dial to the lowest fahernheit temperature setting.
oh and also make sure its not on the ECON setting either...turn the air off...set the knob all the way to the left(65 degrees), then turn it on and hit the auto button....its extremely humid here in houston so i have to drive for about 1/4 mile for my AC to blow cold air but after that its practically snowing...
