https://flic.kr/p/G2Uo13
It's been a while since I played with BB codes, but hopefully you will see an image of one of my wheels above. The problem areas are around the hubs and some along the perimeter. From the research I've done so far it sounds like the way to proceed is to sand down the bad parts (220 grit sandpaper has been suggested) WITHOUT using power tools to avoid damaging the material. Then use finer grain sandpaper to smooth out the scrapes. Then polish and clearcoat.
This all sounds doable to me, since it mostly involves elbow grease and I have a great deal more of that available than money at the moment. Has anybody done a project like this? Any specific techniques or products that you would recommend or warn me against?
Finally, I have had a lot of trouble with stubborn gunk in the inside corners of the small slots in the wheels. I can shoot a closeup photo if that's not clear enough. The problem is that those little slots are damn narrow, and with the kind of curve at the back I just can't get a brush in there with enough power behind it to do the job. My inclination is to Dremel if I can figure out a head gentle enough and pointy enough to get the gunk without shredding the surface.
Anyway, as before I would be most grateful for any information or guidance. My mirror replacement went just fine thanks to the excellent folks here, and now I'm having to re-learn how to drive the Black Beauty without a big weird blindspot in one of the side mirrors! Thanks in advance.
-Mean Machine
