homeslicej2 »
https://forums.nicoclub.com/homeslicej2-u54419.html
Fri Aug 31, 2007 3:48 am
There are 2-3 articles in the tech section about diff swaps, but i understand they can be hard to understand.
Here is some help from KA24DEdevelopment.com If you own an S13 (89-94) you will need to swap the rear cover off your stock open diff onto the VLSD:The S13 uses a different bolt pattern (4 bolts) than the S14 (2 bolts) on the rear cover...
You will also need 2 longer mounting bolts for the S13 chassis, and 2 large washers for the front mounts...to be used with the large bushings on the front mounts. They are M12 X 1.25 thread/pitch, 85mm long.
The stock S13 front mounting bolts are not long enough for the J30 and S14 diff mounts.
And I've seen more than few diffs drop out from the front mounts by not using washers - They need to be ~1.5" diameter or so, and 1/8" thick.
To overcome the .75" extra length at the nose of the diff you can:1) Install it and see if your driveshaft and transmission mounts have enough play to soak up the extra length.
2) Get a driveshaft from an ABS equipped 240SX...it's .75" inch shorter.
Mods, sorry for referencing another site, but just trying to help a fellow NICO member out and not plagarize.
