J30 rear shock replacement
J30inthe sun
Car: 1997 J30
I have search far & wide before posting this.
I need to replace my rear shocks, 1997 J30 99,000 miles.
Can I do this procedure myself?
Do I need a spring compresser?
From diagrams I have seen it looks like 1 bolt on the top of the shock & one bolt on the bottom.
Also, does anyone know the torque specs for these bolts?
Thanks in advance.
yodawill2000
Car: 94 Infiniti J30
Ive heard its just a shock .not a strut so to speak.easy.
7psib20a5
Car: 93' j-30 and 88' prelude si turbo
the rear is a shock ......not a strut...and you will need a spring compressor to dod this job...on 1-10 its a 5
J30inthe sun
Car: 1997 J30
I finally got my rear shocks replaced today
What a difference from even before the rear went out last week.
For everyones info, the shock is removed by removing the nuts that secure the top mount to the body & bottom shock bolt & removing the assembly as a unit. You will need a spring compressor also or should I say obviously.
I replaced the top & bottom rubber bushings, top rubber spring seat & also replaced the boots. I would definately recommend that anyone replacing a shock put all new rubber pieces in. it's worth the extra $31 especially when the shock & boots are $190 each side.
I had a local shop put them in for $130 plus tax.
I feel real sorry for them because half way through the install I asked the mechanic how the old rubber bushings looked? He then picked up the entire assembly that he just replaced the shock in & pointed to them & said they look ok. He didn't replace the new rubber bushings because he didn't go through everthing in the box. He had to remove the shocks again & re-install the rubber bushings & in doing so broke the top of one of the shocks rendering it useless
They had to go to the local Infiniti dealer & get one for $179 their cost
$584.00 total for new rear shocks.
Modified by J30inthe sun at 2:51 PM 3/17/2007
Modified by J30inthe sun at 2:52 PM 3/17/2007
