J30 rear lower links "plinking"
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
A Good friend of mine, swapped my 1994 Q for his 1993 J, today, to have me look at what it needs. That little car really cooks! The engine noise is quite loud, though. I expected th e same quiet ride, but was suprised. Maybe his mufflers are burning out.
The front rotors are warped. Aren't they the same as my Q? I have my old set, I took off, when I put the cross drilled ones on. If they are the same, I might swap them for him.
The rear suspension plinks, when I hit it, and plinks when I hit the breaks. I thought it was the struts, but they are quiet. Joel thought is was more of a squeak, but it is more of a plink.
While I was under the car, it appears the subframe mounts are leaking, because there is a lot of gue on the spare tire well.
The struts have a lot of travel, but don't seem to be bouncy.
I grabbed the rear lower control arms, and they both plinked, when I twisted them.
O.K., the car hs 91,000 miles on it.
What does it need?
Come on, you J30 guys, I need some help!
Thanks:help
sijoko
Car: Black 1994 Infiniti Q45 Turbo, Pearl White 2014 Maxima Sport
As far as I know, the J30 and Q45 rotors are the same.
Regarding the rear suspension: Is it the same design as the Q's?
If it is and the bushings are shot, then you can replace them with Nismo parts for a Z32 300zx.
I replaced all the bushings in the rear of my 94 Q45 with Nismo parts.
Let me warn you, it is a bit of a headache. But it is way cheaper than buying all new suspension parts.
Also, I replaced my subframe bushings with Energy Suspension parts for the Z32. They fit with slight modification.
The rear wheel drive Nissans of the 90s have similiar suspension designs.
-sijoko
Jeff Williams
2000 Infiniti I30t
2004 Infiniti M45
Thanks, It is extremely similar to the Q. Even the exhaust looks the same, except the tubing seems a little smaller.
The sway bar appears to be thicker, than in the Q. Do you think he would notice if I swapped them? :-)
I believe the entire rear subframe is exactly like the Z32, except for the brakes, because the car came with 15" wheels, where the Z32 came with the 16 "wheels.
I found some lower links, for about $50, on "Everything Infiniti" I'll call Joe, in the morning.
I'll price the subframe bushings, and upper links, as well.
sijoko
I don't think the dealer sells the J30 subframe bushings separately.
If they are hydraulic filled bushings like on the Q, then your friend would have to buy a new subframe.
-sijoko
