cody180sx »
https://forums.nicoclub.com/cody180sx-u63328.html
Thu Jul 16, 2009 11:54 am
ok update been a while since i updated this everything works find ran into some some more problems but didn't take more than a few minutes to figure out. If your going to retain your stock axles there is a brass ring that need to be removed it is located on the end that plugs into the knuckle we did it with a brass hammer took like 5 seconds no problem if you go with a j30 axles later on for a diff you dont have to do this being you are using the knuckle it plugs into.
The other thing was i was retaining my stock 240 brakes in the rear and using s14 rotors there is a piece of the e-brake cable were it comes in through the back of the knuckle then through the hub, to run the smaller rotors you havr to remove this piece
there is another piece on the direct opposite side of this one also that need to be removed
but if you want to retain the drum style e-brake i'm pretty sure you can make it work just like the 300zx ones but i haven't done it
also on a side note the j30 traction links are the exact same as the nismo piece it's boxed in just like it
Modified by cody180sx at 3:00 PM 7/16/2009
