J30 Rear End Grease Addition
sahamm
Car: 1995 Infiniti J30
1995 J30 w/ 130k miles::
Wanted to add/check rear end grease level. I can find drain plug, but not hole/plug where you can add grease.
Does anyone know where you can add additional grease to the rear end of a J30?
Thanks!
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
On the Q, the drain plug is at the bottom, and there is another plug you take out on the top, on the drivers side.....
you should drain/refill... cant remember how much it takes.....
Do you have a FSM?
DAEDALUS
Car: 1990 Infiniti Q45
You mean differential oil?
sahamm
Yeah, I suppose it is oil, but of course it's twice as heavy as regular motor oil. I've just heard it referred to as "grease" for years.
sahamm
It is the differential... Sorry for not being clear the first time.
Q45tech
"twice as heavy as regular motor oil" at room temperature but only 5 cSt at 300F.http://www.drivetrain.com/redlinedifflube.html
If you do lots of short under 10 mile trips in winter you can gain some mpg by using the Redline 75/90 NS fluid it will pay for itself [extra cost in a year].......$10 quart x 2..................a 2% improvement in cold and general friction should save 14-15 gallons of fuel per 15,000 miles.
130k is a little late hopefully someone changed it at 60k, I change mine every 30k after learning the hard way with diff replacements over the years.
The diff efficiency is critical to rear wheel HP as the diff is very inefficient at low speeds [93%] vs 97% at 60 mph...........the 75/90NS is almost 0.75% better at 60 mph and 4% better at 5 mph.
sahamm
Good info, but where's the hole to put it in on the J30?
Thanks!
vehornr
Car: 1995 J30
you've probably found it by now, but if not it's on the driver's side, fairly high up. it's a b*tch to get the new oil in!
Q45tech
Not with the proper pump or even a hand syringe pump. Pretty much all [every car/truck] rear differentials are the same [locations vary] as to the method of draining and refilling.
vehornr
Car: 1995 J30
yeah, well, it always helps to have the right tools
