Eswift »
https://forums.nicoclub.com/eswift-u367.html
Sun Mar 02, 2003 6:35 am
if my memory serves me, there is a yellowish resin-looking ball in the center of the wire. it would be good if someone else could confirm the coloration. If yours is dark, that could be an indication that there is gunk all over the outside of your wire, which could definitley effect heat transfer rates, and hence, the MAF reading being offset. a less effective heat transfer would indicate to the ECU that less air was flowing than actual, so that could be the problem right there.
