DustnF1 wrote:J30 Q's I have just joined the forum and am exited to have finally found you all. I have a 96 J30 and am getting ready to do some work. Any tips or heads up on the problems about to be addressed would be very helpful. Thanks in advance.
1) Brake Pads and Rotor replacement
2) Popping from front steering. Not sure if I need to replace whole Rack & Pinion or not.
3) transmission issues.....car stalls out SOMETIMES when making sudden stops from slow speeds.
4) Torn boots on front suspension
-Timing belt must be replaced @ 105k miles on a 96. Do a search for that and you will learn of the other things that can be done at the same time. Do this ASAP otherwise major engine damage will result.
- Popping? Could be any number of things but I'd guess tie rods and/or bump stops.
- transmission pan drop and filter change and check to make sure the transmission cooler isn't clogged. The damage may have already been done, however.
- Don't worry about the boots. Replace them when you bet new struts. This isn't cheap but good deals can be found on parts using our sponsors. Everything Infiniti is great.
You don't mention your mileage but I'd guess you have at least 120k.
Welcome to the club.
