J30 Power Window Motor w/any other Infiniti?
RideInMyJ
Is there a cross reference for the Drivers side power window motor with any other Infiniti/Nissan motor?
VimyJ
If you're having problems with the window, it is most likely the window regulator that is causing the problem.
RideInMyJ
nope. its the motor, the gear inside is complete mush.
VimyJ
One rarely hears of the motors going bad and when they do its because the regulator is binding. That said, the good news is that you could go to a salvage yard for the motor since they rarely fail.
carlos_knology
Car: 1995 Infiniti J30
RideInMyJ wrote:nope. its the motor, the gear inside is complete mush.
I've replaced two window motors in my J30 with rebuilt units from Advance Auto Parts.
At the time (two years ago), the cost was around $50.00 provided you give them your bad motor as core.
The motors had a "lifetime" warranty (as long as YOU own the car) so I took the gamble. So far, so good. It's been over two years and knock on wood, no problems with the rebuilt units.
Carlos
HeavyDuty
Car: 1995 Infiniti Q45
95 Nissan 240SX S14
96 Nissan D21
06 Nissan 350Z Z33
That makes sense about a bad regulator taking out the motor, VimyJ. My motor was smoked, smelled like a model train transformer on Christmas morning. My lower window alignment pin was broken, too, prolly caused by mis-alignment of the regulator.
I thought about a junkyard one, but who's to say the regulator in the junkyard car was good? FI, imho, I'll deal with it & move to the next expense. =)
