carlos_knology »
https://forums.nicoclub.com/carlos-knology-u278.html
Sun Oct 24, 2004 3:21 pm
The PS pump is not near the fluid reservoir. The pump is in the front of the engine. It runs off one of the belt pulleys. Lower left (as you face the engine) if I remember correctly.
According to the manual, the pump replacement criteria is:
Replace if you find for leaks around the pump.Replace if you find a deformed pump pulley.Replace for poor performance (can it be any more vague?)
