Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Sun Oct 12, 2003 1:35 pm
Sounds about right for dealer, an independent might be able to save you a few bucks on labor..............usually happens at higher mileage but your driving style may be a factor in early clogging.
If you bring it down to T3 Atlanta we can PROBABLY clean them without pulling the transmission. We have a type of homemade EGR roto router with 3 differing diameter cutters driven by a drill...........cost $310........4 hours labor plus cleaning solution..............works 98% of the time.
About 3 hours each way, perfect timing, and you'll only be gone 12 hours. plus $27 of gasoline.
