J30 Parking Lights
terry47
Car: 1994 J30T
Having a couple of issues with the parking lights on my 94 J30T. Both front parking lights went out at the same time and just one side marker is lite. Do these lights run in a series? How do I check the bulbs to see if they are burned out?
gr8scott72
Car: 1994 Infiniti J30t
terry47 wrote:Having a couple of issues with the parking lights on my 94 J30T. Both front parking lights went out at the same time and just one side marker is lite. Do these lights run in a series? How do I check the bulbs to see if they are burned out?
No, they don't run in series.
Pull the bulbs out and replace with new.
naladude911
Car: 2001 Infiniti QX4
whats ur email? I made a powerpoint of step by steps on how to remove the pking lights. http://www.cardomain.com/id/j30dude
Tdawgg
Car: 1993 Infiniti J30
Do you still have the PowerPoint with step by step for the parking lights for J30? If so can you please send to [email protected]?
Thnx
swimshark
Car: Bamboo Mist 1994 Infiniti J30 Soon to RIPs
Pearl White 1993 Infiniti J30 Project Ghost
i can take a pic later on of how you can pop them out easily. ill get some when i go on lunch break.
Tdawgg
Thanks swimshark..... I hav been looking all over the Internet and can't find anything. I look at them myself and it looked like I would have to take half the freaking' electrical out of the front end.... Seemed to much work to check the bulbs seeing how I don't think it is illegal to have no parking lights in illinois where I live.
Thnx in advance
swimshark
Disclaimer: the side of the car I could get pics from easily is the side that kissed the side of a mtn so my bumpers are messed up.
All you need is a small flathead screwdriver.
For the front, you will stick the screwdriver in the location shown below. You can put a cloth on the bumper where the screwdriver will be touching so you have less change of messing up the paint.
Then pop the light out
Then all you have to do it twist the bulb holder out of the lens
For the rear you will stick the screwdriver in the location shown below and do the same things as the front marker
Tdawgg
Thanks alot. Do you happen to know if the front blinkers come out the same way? The ones that you replaced with your old grill. Also do you know if they are dual element bulbs that come on with the headlights?
Thnx
swimshark
the front blinkers are held in by 2 10mm nuts. you have to drop the debris shield on either side (held up by the 3 phillips head screws per side). you need either a 10mm wrench or a deep socket 10mm.
the headlights (low and high beam) are both single element. the low is the 9006 and the high is a 9007 single.
texml69
Car: 1993 J30T gold package
naladude911 wrote:whats ur email? I made a powerpoint of step by steps on how to remove the pking lights. http://www.cardomain.com/id/j30dude
any chance i can get you to email me the steps on removing the parking lights next to the head lights
[email protected]
