joe_j30 »
https://forums.nicoclub.com/joe-j30-u9598.html
Sun Aug 24, 2003 7:36 pm
I finally got my car back after 3 days.
The transmission is good and smooth now. This is what happened.The diagnostic returned 2 trouble codes:1. Temperature sensor2. Turbine sensor
When the mechanic replaced both parts, they found out that the oil presessure solenoid is broken (they said it could be originated from burnt temperature sensor, and never been replaced for a long time.) Unfortunately, they dont sell the solenoid seperately, so I had to get the solenoid pack (there are 4 solenoid total -> solenoid a, b, c, and the oil pressure solenoid).
The transmission oil is flushed twice (not intentionally), and the filter is very clean, so no need to be replaced. I called infiniti, but they dont have the filter. Instead they have the filter cleaning kit. Any idea?
Anyway, if you guys have similar problems, this could probably help. Actually, the one original problem originated from the solenoid. So in away, I learned a lesson. Fixing trouble codes will not necessarily fix the problem.
If you guys live in Houston area, I can recommend you this mechanic. He's very honest and pretty cheap . He used to work for southwest infiniti since 1990, but he moved to volvo dealership now. Talking about knowledege about infiniti, this guy's been there well over 10 years fixing infiniti.
